It is currently Wed Aug 20, 2025 6:49 pm
PostPosted: Mon Mar 10, 2014 10:03 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Just curious.
best,
Miguel.
PostPosted: Mon Mar 10, 2014 10:07 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I don't, or if I do I don't know it.
I apologize for my ignorance, but what ruler trick?
These users thanked the author mkellyvrod for the post: Bryan Bear (Fri Mar 14, 2014 7:59 pm)
PostPosted: Mon Mar 10, 2014 10:09 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Is that where you measure before you cut? I've been thinking about incorporating that technique in my next build...if I can afford it.
Doug
These users thanked the author Doug Balzer for the post (total 2): Shaw (Tue Mar 18, 2014 2:56 am) • Ken Jones (Mon Mar 10, 2014 12:38 pm)
PostPosted: Mon Mar 10, 2014 10:11 am
First name: Justin
Last Name: North
City: Chattanooga
Zip/Postal Code: 37416
Are you talking about lining up the neck angle using a straight edge to gauge the approximate height of the bridge and saddle to make sure you have the correct angle on the neck before attaching the neck?
PostPosted: Mon Mar 10, 2014 10:23 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Hey,Doug that sounds like a good idea laughing6-hehe
PostPosted: Mon Mar 10, 2014 10:44 am
First name: Miguel
Last Name: Bernardo
Country: portugal
sorry folks, i´m too deep in my own, er, thing - didn´t occur to me you guys could not know it.
It´s that thing where you use a thin ruler layed upon an edge on the surface of your fine waterstone and flatten only the utmost tip of the back of your plane blade on the other edge, thus creating a minute back bevel on the tip of the blade. saves lots of time and is quite popular. i believe credit is due to David Charlesworth, or at least he´s the one i got it from in the 1st place. If you search youtube for Mr. charlestorth or LN´s Deneb Puchalsky you should find more info.
Doug: you made me laugh, man. thanks for that, always worth it!
best,
Miguel.
PostPosted: Mon Mar 10, 2014 10:56 am
I use it with very good results [:Y:] Started last spring when I saw Rob Cosman use it in a few of his DVD's, and saw Deneb use it in his sharpening clips on the Lie-Nielsen YouTube channel.
PostPosted: Mon Mar 10, 2014 10:59 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
best,
Miguel.
Do you still put a 30 degree micro bevel (or whatever is your usual micro) on the face?
PostPosted: Mon Mar 10, 2014 11:13 am
First name: Miguel
Last Name: Bernardo
Country: portugal
yes, i do. but i´m not an expert on anything. i´m just lazy.
PostPosted: Mon Mar 10, 2014 12:28 pm
City: Calgary
State: Alberta
Yes, it works great for plane and spokeshave blades. Don't use it for chisels.
PostPosted: Mon Mar 10, 2014 3:03 pm
No
PostPosted: Mon Mar 10, 2014 4:57 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
Care to elaborat link?
PostPosted: Mon Mar 10, 2014 5:41 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I do something similar in creating a micro bevel but use the Lee Valley honing guide that enable you do cut a micro bevel without taking the blade out of the guide...very accurate.
http://www.leevalley.com/en/Wood/page.aspx?p=33001&cat=1,43072,43078&ap=1
Doug
PostPosted: Mon Mar 10, 2014 6:51 pm
Online
Yes, found it early on, and I've always used it for plane type blades. Magic.
Tried it early on for a chisel.
Took me ages to flatten the back again. [headinwall]
PostPosted: Tue Mar 11, 2014 11:52 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Do you also use this with block plane blades that have a chip breaker? If so, where (in relation to the tiny back bevel) do you set the edge of your chip breaker?
PostPosted: Tue Mar 11, 2014 11:55 am
I really thought it was for use on bevel up blades without a chip breaker, but I could be wrong. I can't see the advantage on a bevel down blade, other than presenting a higher angle to the wood instead of having a higher angle on the frog. Chip breaker would still be close to edge.
PostPosted: Tue Mar 11, 2014 12:30 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
+1 on what Doug said about the Lee Valley guide
Gene
PostPosted: Tue Mar 11, 2014 12:40 pm
First name: EddieLee
Last Name: Brown
Yes It does save time and seem to work just fine.
_____________
EddieLee
PostPosted: Mon Mar 17, 2014 1:06 pm
First name: Charles
Last Name: Tauber
City: Brampton
State: ON
The Charlesworth technique is to put a small bevel on the back of a plane blade/iron. The purpose of it, as I was taught it, is to save time: the back of the plane blade/iron doesn't need to be flattened. The small, localized bevel on the back eliminates that need, while still creating a fine line at the intersection of the bevels of front and back of the iron. Without the bevel on the back, the back of the iron needs to be flattened for a sufficient length that it forms a flat plane to give the needed line-intersection between back and front of the plane iron. For those that have "fettled" plane or chisel blades to get a dead-flat back, the time savings is a few hours of initial work.
I don't use the "trick" since I flattened the back on most of my tools prior to the introduction of the technique. Consequently, using it doesn't save me anything.
PostPosted: Mon Mar 17, 2014 4:15 pm
City: Alton
State: IL
I do it on my plane blades. Do do it on chisels.
PostPosted: Mon Mar 17, 2014 4:41 pm
Online
Evilfrog, don't you mean Don't do it on chisels!
PostPosted: Mon Mar 17, 2014 5:09 pm
State: Tennessee
Same here no problems with flat backs :mrgreen:
Users browsing this forum: Colin North, Ken Lewis and 17 guests
